Try shutting it down, pull the battery for a minute, put the battery back in and try again. What are you using, Modis? I have had similar problems in the past but it went a way. Make sure the battery is good and charged. You can try using the wall power adaptor. If that works but happens again without it. You could need a new battery. Good Luck.
Dear, you may try to use the PS3 recovery options. The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this:
Make sure the PS3 is turned off
Press and hold the power button on the PS3 it will power on then power off.
When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
It will ask for the controller to be connected via the USB cable,
Turn on the controller and you will have access to the menu.
Be aware that you may lose all your data previously saved.
Good luck,
Peter
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3
is in standby mode(red light) till you hear a double beep. sometimes
the ps3 does a beep then another beep and goes back into standby thsi
is fine just release the power and quikly press and hold it again till
you get double beep.
like on my 80g system it goes like this
ps3
standby...press hold power.......beep .........beep........stanby
again....release and hold power again.......beep .........double
beep...release power now you should be in recovery menu.
ps3
when ps3 is in standby mode(red light) press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
then take it back as these steps will not void warrenty
rebuild the file system and the database in the recovery consol.
to get to the recovery consol when ps3 is in standby(red light) press and hold the power button till you hear a double beep then release. if the light turns red before the double beep quickly release and hold it again and wait again.
my ps3 goes like this
ps3 standby mode...press hold power button......."beep"......"beep"........standby again..release then hold real fast........."beep".........."double beep beep"....release and there are the options to rebuild database and filesystem. database and file system wont delete saveed files. i have some other tricks so let me know but try this first.
