it sounds like a wiring problem i have seen these in many in dash dvd players. if you still have the manual just check your connections and your grounds there may be a short or mis matched wire
did ya sdo it self cuz if soo you probly forgot to hook up the ignition wire because cds will eject while car is off check for power at ignitiion wire the red one coming from deck harness and then get back to me
1) Make sure the device is on. 2) Hold down the DVD button and the power button simultaneously until the
red light stays on solid. 3) Then press the power button - it will flash
one time - keep pressing slowly, letting it flash until the device
turns off. 4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
Try resetting the unit by pressing the small, recessed button on the faceplate with the tip of a pen. If this doesn't work, the player may be defective. There is no wiring error (including failure to hook up the parking brake input) that will prevent the unit from playing CDs.
