Hi i have saeco royal professional machine and i am having a small problem and i am asking for your advice how to fix this problem. Suddenly the coffee machine started giving half cup less coffee then normally. Is it because by mistake i reset the quantity of coffee or can there be any other reason for giving less coffee. I will be really grateful if you could help me in this matter.
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
SOURCE: my Saeco Royal Professional
Okay! This can be 1 of 2 things. 1. Your machine button needs to be programmed. Do this by holding the button down until the coffee is dispensed to the height of your likeing, then let go. The button should now be programmed. 2. Your machine is leaking internally and some of the water that should be going into your cup is going elsewhere. Also try descaling your machine. For more info go to: www.cerinicoffee.com
SOURCE: Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
SOURCE: SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
SOURCE: how do I check how many coffees we have made on
Hi
Push and hold the menu button. When is says "energy saving" use the up arrow and go up about 3 or 4 pushes until you get the * beside the "total coffee", then push the menu button again. The menu button is what gets you into the selections and is what locks changes in the computer.
SOURCE: No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
