My Delonghi Primadonna coffee machine is fantastic but this morning I can't insert the milk container. The hot water spout works just find and gives the positive beep when inserted but the milk container just doesn't seem to fit! Nothing else on the machine has changed (position etc). Hopefully there is someone out there who can help - I need my Latte Macchiato
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
Add a little Petrol-Gel Food Grade Sanitary Lubricant to the two O-Rings on the machine were the milk container connects. If you do not have that available, wet your fingers with water and rub on O-Rings prior to inserting milk container. O-Rings dry out and go bad, they need lubricant. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
O-O
