Linksys E1550 Wireless Router - Refurbished - IEEE 802.11n - 3 x Antenna - ISM Logo
S
Steve Hulslander Posted on Nov 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to reset passwork on linksys e1550 to default
Need to reset to default password.
Jeff richtman
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Dec 28, 2013
Jeff richtman
Expert
Level 2:
Sergeant:
Answers
324
Questions
0
Helped
62757
Points
909
The only way to reset password to default if the existing one has been forgotten is to do a full factory reset.
On the back of the router there is a small hole that will say "Reset" above it. Using a pen, paperclip, or other small item. press and hold the button for 30 seconds while it is plugged in.
Disconnect power for 30 seconds and plug the router back in.
This is usually sufficient to reset the device back to defaults. If this method fails repeat the above but after plugging power in for the last time Hold down the reset button for another 30 seconds.
Make sure you count slow, as holding the button too long is better then not holding it long enough.
Unlock E1550
For most versions of the Linksys E1550, the default password is admin. As with most passwords, the E1550 default password is case sensitive.
I dont know the user name or passwork for my linksys wrt54G router how do i find them
On the back of your router is a 'reset' button. Use a toothpick or a pen to press it for approximately 5 seconds. Once this is done you can log in with the default user and password.
  • Open your web browser
  • Browse to 192.168.0.1 or 192.168.1.1
  • The default username is: (blank)
  • The default password is: admin
Only type in the password, and don't enter anything in the username field. In case this doesn't work try the following credentials:
  • Default username: admin
  • Default password: admin
Reset password on linksys e1550
There should be a small button which can only be reached with something small like a paperclip in the back of the router. If you press and hold this for 30 seconds or so it will reset ALL of the settings to default. Warning! This will clear all internet username and passwords, you will need to get these back from your ISP.
Where to inter att logon and passwork
You can check with your service provider to make sure what default admin and password they have for such device or alternatly check your device manufacturer website for default credentials.
Forgot pasword
Right there in the online manual, there's detailed instructions (you have to press a secuence of buttons to reset it)
Linksys E1550 Online Manual
Linksys E1550 owner need guest password
Steven,
You MAY find this PASSWORD LINK very helpful!
An Updated List of Linksys Router Default Passwords
Get the FULL MANUAL here:
http://downloads.linksys.com/downloads/userguide/E1550_EN_UG,0.pdf
WARNING!! THE FOLLOWING WILL RESET EVERYTHING!!
(and I mean *everything* back to "Factory Settings")
The TOTAL ROUTER RESET instructions are:
Press and hold the Reset button on the E1550 at the bottom panel for about five (5) seconds then release, or access the web-based setup page then go to the Administration tab > Factory Defaults and click the Restore Factory Defaults button. To know more about this, click here.
BASIC RESET FOR ALL LINKSYS ROUTERS:
Step 1: Locate the Reset button and, using a pen or a paper clip, press and hold the Reset button for 10 seconds. QUICK TIP: For router models such as the Linksys Wireless-B and Wireless-G routers, press and hold the Reset button for 30 seconds.
Hope this helps!
Anthony
I forgot my securiy code phone?
is it phone password or router password. do you mean wep or wpa passwork? you can access these security key by accessing your GUI in you router. just open your internet browser and type in in the url 192.168.1.1 for "linksys" router or 192.168.0.1 for other router. then go wireless and wireless security. you can find there if your are using wep or wpa access key.
In case that you dont know the password of your router. reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router. On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
2answers
Do not remember passwork
if you have changed the password from the default, you must reset the router.
then you can use the default password.
if you have not changed the password, and simply dont remember the default log on is:
username: (keep blank)
password: admin (all lowercase)
1helpful
How to set Password on Linksys Router?
..hi..hello...if you don't remember the password their is a simple way about..try to find small hole at the back of router the name is reset,so u make a resets using small pin.reboot the PC/CPU when the router is connected then after reboot re-type again (192.168.1.1) then u see again the box of Linksys only u need enter the box is Password the password is (admin)..good luck and Thanks...
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
