Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
