Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
I have a life fitness treadmill 9500 it is showing external ram error !!What does this mean
Life fitness will not start showing a error external ram error
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
    New Friend:
  • 338 Answers
Get in touch with Life fitness. They will have the parts as well.
Could be motor problem. Maybe.
Posted on Nov 12, 2013
SOURCE:
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
SOURCE: I have a life fitness T3 showing an error code 5.
running error
Posted on Jan 10, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Posted on May 07, 2010
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
Lifestride 9500 treadmil show noilfy maintenance display
proceed with the instruction manual maintenance, if you do not have go for free download : www. fitness.manualsonline.com or www.iconservice.com
RUN THE software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 07, 2012 | Life Fitness Lifestride 9500 Treadmill
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
May 03, 2010 | Life Fitness F3 Folding Treadmill with...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
434 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
