When I try to enable the wifi it says enabling and then restarts the phone without wifi on
SOURCE: LG KC910 connecting wifi to my home internet
I had this problem, My wirless router is using WEP Authentication with a "Shared Key". I had to change this to either Open or Automatic on the router.
SOURCE: LG 910 Internet Settings Problem
i had the same problem with my 910 , i rang my service provider and they text me the codes and software to load directly onto my phone , problem fixed straight away !
SOURCE: lg kc 910 security key
the default setting for security code on the renoir isnt listed in the manual but is 0000 (four zeroes) which youll need to change the code or access some of the features
SOURCE: LG Kc910 connectivity to pc/wifi
3845#*910# Master Reset code for lg kc910 , once in do a factory reset
SOURCE: LG KS 360. FDN enabled.. means what?
i have managed same problem as u. FDN means fixed dial number so all u have to do is to go in meniu...settings..security...and nr 4 is the submeniu u need.(just select stopped/turn off ..but be carefoul, it will ask you the pin2 of the sim u have in) After this,will appear a message" finalised" and u may call wherever u want.
