E90 is a communication error between the main pcb and the display pcb.Check the blue wiring loom that goes from the main pcb to the display pcb.normally it is a bad/loose connection on the display pcb end.clean pcb tracks and tighten the blue connector loom pins up and hopefully it will work.if it doesn't solve the problem then you could have a faulty display pcb or main pcb.
Hey friend, thank you for your post!
From my understanding you are receiving an error code of "E90" on your Frigidaire washer. I am showing that as an invalid error code. It might be a miscommunication with your control panel and I would suggest performing a reset on your washer. In order to reset the washer you would need to disconnect the power from it for roughly ten minutes. If you continue to receive an error code of "E90" I would suggest contacting a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
E90 IS THE ERROR IT IS SHOWING ...
how to open this panel
