Question about Technics SL-1200 Turntable
Technics sl-dd33 skipping
Two thirds of the way thru an album it starts skipping
SOURCE:
  • 42 Answers
SOURCE: The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Posted on Jan 24, 2009
  • 133 Answers
SOURCE: technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Posted on Sep 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: My turntable is Technics model
Define what isn't working. Is it dead (no motor, lights, anything)?
Or is there just no sound. The output of the cartridge is independent of any power. A basic test to see if it's alive is to lift the tonearm, select the Phono on your electronics, TURN THE VOLUME WAY DOWN TO JUST A SKOOTCH OFF OF SILENCE, place the tonearm somewhere over the platter and lightly brush the stylus (BACK TO FRONT) with your finger tip. You'll hear objectionable noise from both channels if the conenctions are all intact.
Posted on Dec 12, 2009
STYLUSCITY
  • 271 Answers
SOURCE: SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
Posted on Sep 13, 2010
SOURCE: Technics SL-DD33 Turntable
Just plug in a single wire from a normal electric wire - between the screw and just into the groundhole - as i remember
Posted on May 29, 2013
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
I have a technic sl 1200 mk2 , my anti skate is
I gather you don't know how to adjust the tonearm. First put the stylus pressure, and antiskating to zero. Balance the tonearm for a free floating position. Ortofon cartridges will list the stylus pressure, generally 1.5 grams. Dial in the correct pressure, and set the antiskating to the same as the stylus pressure. If you require more assistance, or would like to inquire about repairing your Technics, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 09, 2014 | Audio Players & Recorders
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
The cartridge arm does not go back to the off position.
it's a "manual" turntable so this is normal. You would need to buy an "automatic" turntable to have the arm return back when done.
Apr 22, 2010 | Technics SL-1210 Turntable
My turntable is Technics model SL-DD33 and all of a sudden stop working I changed the power supply cord and it didn't fix the problem. Will you please advise or where I could take it for repair and if it...
Dec 12, 2009 | Technics SL-BD22 Turntable
I have a technics sl-pd887 5disk changer that
I contacted a friend who operates a sterio shop and was convinced that fifteen years of bouncing up and down has made the laser unable to focus and read the info on the disks and the solution is to buy another one . Thanks for you're interest.
Nov 20, 2009 | Technics SL-PD887 5-Disc CD Changer
Jan 16, 2009 | Technics SL-BD22 Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Well, it will play, it will just be very annoying to hear that humm. Unfortunately, you cannot get the wire plug from Technics, as it has been discontinued. So, the only other option is to take it to a service center, and have them 'hard-wire' a ground table to the unit. This entails opening it up and running a ground wire from the inside of the unit. Shouldn't cost you much, and should take about 30 min or so to complete. If you are quoted more the US$40, take it else where.
Any qualified electronics technician should be able to handle this. It's Audio Repair 101 - very easy stuff.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairny.com
www.1200s.com
May 10, 2008 | Technics SL-BD22 Turntable
Open Questions:
Technics SL-1200 Turntable Logo
111 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
