When using a HDMI cable, and playing PS3 games, the only audio present is a very loud clicking noise, coming through the speakers of the TV. Everything was working fine until about 2 months ago. I didn't change a thing, but we did have a power outage. Since then, I've tried using component cables, playing PS2 and PS3 games with both the HDMI and the components, playing movies (DVD and BluRay), but the only time the clicking sound is present is when it's a PS3 game, and using the HDMI cable. In all other scenarios, the sound is fine.
SOURCE: PS3 hdmi Audio problem Crackling Sounds
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
SOURCE: no video display,
PS3 is The amazing device by sony but it has some common problems like no video display,sound problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
SOURCE: sound but no picture on PS3 using AV3/4
you shouldent be putting the hd cable in just put in the scart and the wire and you should be fine
PS3 Clicking noise is associated with the hardware aspect, so that's your starting point it may come from the PS3 fan clicking, so do check out the fan if there's something that might have got stucked in between. Clogs from too much dust or dirt may also cause PS3 clicking sound.
PS3 clicking noise may also come from the hard drive. The hard drive are a bit noisy because of the mechanical parts and moving drive head when reading and storing data. Again, if the noise level is very minimal, there's no worry. PS clicking noise fro the hard drive that becomes too audible may signify that the hard drive is having mechanical problems and may soon broke down. At this point you may want to backup any data you have
I hope this helps you.
