Cars & Trucks Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spark plug gap
What is the spark plug gap for a 2003 pontiac sunfire? It is not posted under the hood.
Harvey N Tawatao
Level 3:
  • Pontiac Master 3,854 Answers
  • Posted on May 02, 2009
Harvey N Tawatao
Pontiac Master
Level 3:
Answers
3854
Questions
0
Helped
2796857
Points
16501
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
Ray Keckeisen
Level 3:
  • Pontiac Master 599 Answers
Ray Keckeisen
Pontiac Master
Level 3:
Answers
599
Questions
Helped
271880
Points
2229
The spark plug gap is .42 and the torque is 15 ft lbs please rate my fix
Anonymous
Level 3:
President:
  • Master 710 Answers
Anonymous
Master
Level 3:
President:
Answers
710
Questions
0
Helped
351826
Points
2627
IT SHOULD BE UNDER THE HOOD ON TOP OF THE HOOD OR ON THE AIR FILTER ON A WHITE STICKER THAT TELLS YOU THE ENGINE SIZE. ON THE BOTTOM OF THE STICKER. HOPE YOU CAN LOCATE IT. GOOD LUCK
Spark plug gap on a 2001 Pontiac sun fire 2,4 liter
Gap
For 2.4L-- Allow a gap of 1.27 mm (0.050 in).
Tighten the spark plugs to 18 N·m (13 lb ft).
Apply dielectric lubricant GM P/N 12345579 (Canadian P/N 1974984 or equivalent to the insulator boots.
What is the spark plug gap?
The spark plug gap is the distance measured from the ground piece that is bent at a 90 degree angle over the center post to the center post of the spark plug..
This distance should be around 0.035" but is slightly different in all cars.
Hope this helps you.
Need gap spacing for spark plugs. Wondering about the location of the fuel filter
Hello: There should be a white placard under the hood giving you the spark plug gap, Its called an ession label for your engine, the gap probably is .060 of an inch. The fuel filter should be behind the fuel tank or to the passenger side under the rear of the car.
I.m trying ti change the spark plugs on my 2003 Pontiac Sunfire 2.2 EF and don't know where they are located
they are under the cover on the top of the engine a couple of bolts on each side ten mill
1helpful
Spark plug gap?
Should be on a sticker on the underside of the hood or somewhere in the engine compartment.
3helpful
2answers
Location of the fusebox on a 2003 pontiac sunfire
My 98 Sunfire has a fusebox when you open the door on the drivers side on the side of the dash. Should be the same for an 03. And yes, on the same side under the hood is another fuzebox for your lights and signals etc.
4helpful
Spark plug gap for 2004 jeep grand charokee for Bosch Platinum + spark plugs?
The spark plug gap should be posted on the emissions sticker under the hood. The gap setting posted on the sticker is good for all brands and types of plugs for your vehicule
Spark plug gap
call a part store like auto zone they can tell you this.
Spark plug wires correctly installed on pontiac sunfire
you need to know the firing order and then where #1 plug wire goes. Need a shop manual.
Distributor or distributorless ignition?
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
