Televison & Video Logo
Posted on May 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture is wavy, dark and displays only black, blue and red.
I have a Mitsubishi CS-35701 that I bought new back in 1993. It has always been a very reliable TV.
The problem I am having now is that the picture, on all channels and inputs, is wavy, dark and displays only black, blue and red. Sound works great.
What might the problem be? And I could use advice as to what would be the most economical avenue I could take to have it repaired.
Thank you,
Joe
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on May 02, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
63065
Points
407
Yes, send to repair, the problem you are showing is not a big problem for any regular workshop. The tv needs now a regular "maintenance" some parts are old or some solder joints are old, in any sense a "good day of service" working this tv in the bench is not really expensive.
1helpful
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
3helpful
Mitsubishi CS-35X7 CRT TV (vintage 1993) no picture
THE PIP MODULES GO BAD IN THESE SETS. THEY PLUG IN AND ARE EASY TO CHANGE AND EVEN CHEAPER IS THE PIP BYPASS MODULE. IT ELIMINATES PIP AND PLUGS INTO THE SAME SPOT
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
1993 ford taurus
Would you be aware if there is a pre-installed external amplifier attached to the old head unit?
If yes, the speakers are connected to the amp and not to the new CD player. There should be a pair of shielded wire with RCA male connectors that should go to the head unit and the other ends would be attached to the amplifier. Additionally, there is a trigger wire from the head unit that switches the power of the amplifier to ON aside from the power B+12 and GND.
If no, on the Ford pls verify that:
Green/Yellow - always on B+12VDC (positive battery terminal)
Yellow/Black - switchable +12 (ACC terminal of your IGN switch)
Black/Light Green - chassis ground
Orange/Blue - remote trigger on for power antenna or external amplifier(s)
Light Blue/Red - park light
Speakers
Orange/Light Green LF+
Light Blue/White LF-
White/Light Green RF+
Dark Green/Red RF -
Pink/Light Green LR+
Dark Blue/Orange LR-
Pink/Light Blue RR+
Light Brown/Red RR-
(R-right, L-left, F-front,RR-right rear)
On the head unit, often, the yellow normally goes to the always on B+12 such as the + terminal of the battery, the red to a switched B+ such as the ACC of the IGN switch and of course the black to the chassis/ground.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
14helpful
2answers
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
