NVL333EYOWW the dryer works fine with the timer, starts shuts off heats fine, but if the door is opened with time left, the drum stops spinning but heater stays on until the timer is switched off
As soon as the timer is turned to heat the heater comes on, with the door open, after shutting the door and turning the start switch the drum will start and will run its course
Your heating element is grounded / shorted out. It will need to be replaced.
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
SOURCE: PROBLEM WITH HOTPOINT DRYER
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1811&modelDesc=DRYER&modelNumber=NVLR333ET0WB&documentID=E2136683&documentTypeID=PLDM&documentClassCode=PV&titleType=DRUM%2C%20BLOWER%20%26%20DRIVE%20ASSEMBLY&titleID=00004&
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
SOURCE: hotpoint dryer nvl333eyoww
You need to check the heater element and or thermostats for continuity. You will need a meter to do this
Replace if found to open circuit.
Plz rate this solution.
Thanks.
SOURCE: Hotpoint DLB2450 dryer need access to heater elements
Open the door. Remove the screws inside the top of the door frame to raise the lid.
Start switch on motor was shorted, was allowing electric to goto heater without motor running
replaced and now works great
