Innovage Mini-Digital Camera Logo
Anonymous Posted on May 01, 2009
How to delete pictures on INNOVAGE mini digital camera?
I forgot how to delete pictures from the memory. i cannot find the manual. i know i push MODE button till the command and then hold the shutter button down.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
412
Points
To clear the last photo, push MODE button till you see CL and hold the shutter button.
to clear all photos, push MODE button till you see CA and hold the shutter button.
go here for manual and drive; http://forums.cnet.com/5208-7593_102-0.html?messageID=2849222&tag=forums06;posts
I have an innovage mini digital camera and i dont know how to work it
look for your manuel that came with camera it should tell how to use it.
1helpful
My camera says "internal memory
put the camera in playback mode so you can view the pictures. As you view each picture push the menu button and choose delete. Delete each pic this way and your internal memory will be clean
1helpful
I managed to acquire the users manual. But I think I need a driver to download pics. I also don't have a registration Or lisence #. Can you help?
Does this camera use a memory card? If so, use a card reader to download your pictures to a folder you create on your desktop.
2helpful
2answers
Digital camera works, Pc camera shows blank screen(or black screen)
need to know how to use dual mode and need directions for how to use innovage mini digital camera.
1helpful
Need driver/software for innovage key chain mini digital camera
Manualfox.com is a personal Document Search Service for electronic user and service manuals + drivers. They help you to save time and money by finding your needed product information.
Lost magnavox digital keychain manual
Having lost the owners manual I had tried everything to delete all the pictures at one time but couldn't do it. Evidently I had skiped one - the CA mode - which when pushing the shutter button once, while flashing - solved the problem.
Jerry North
Memory stick eject
well to record onto, switch the power button to "camera mode". this will let the camera know to record as well as take pictures onto the memory stik.
As for ejecting the memory stik, jus simply push it INWARD gently and it will spring OUTWARD toward you. to put it bac, do the opposite till the card locks into place
Loading innovage mini digital camera into pc
i only know 1:
To DELETE PHOTOS:
1.click the button on the front near mode
click it 6 or 7 times untill the CA button comes up
when it does click the button on top.
DONE
TAKE A PICTURE:
1.point to where ever the thing/person you want to take a picture of
click the button on the top untill you here a beep that means you took a pic.
keep taking pictures untill you here a beep beep that means you cant take any more pics untill you delete some or one( when your deleting one you can ONLY delete the last one you took) or just all.
then connect the usb to the camera and computer and click "MY CAMERA" (the program you downloaded for it if you didnt download it then do it.)then view the pics to save them on your computer the save is at the top left you can save all at once or individualy.
DONE
Delete pictures
Look for a little icon on one of your buttons, it should be blue, it will look like a little trash can. Make sure your camera is on review picture mode, and then push the button to delete the photo.
Memory
I dont think there is a format memory. Only a delete all. here are the instructions.
Mode 6: Delete All - The Delete All mode is used to erase all of the
pictures from the chameleon Mega. Press the Mode/Power button 3
times until the square with line across it is blinking. Press the Shutter for 3 seconds to delete
all of the pictures.
Here is a link to your cameras manual:
http://www.largan.com.tw/digital/download/manual/ChameleonMega/Engish/Mega%20manual-V02.pdf
Top Innovage Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Innovage Camera Expert? Answer questions, earn points and help others
