Sony DVP-NS575P DVD Player Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony dvd player... black square appears - Sony DVP-NS575P DVD Player
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on May 01, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
63058
Points
407
This feature is related to the tv.
The black square is an space reserve for text. Most of broadcasting companies dont use it at all. Now to evoid it you go into menu look for close caption options and make sure to send the TEXT feature to off, Again in the TV MENU. Details and information about this feature is in the user's manual, specially how to turn it off.
  • Anonymous May 01, 2009
    this feature is related to the tv.
The videos appear black and white when i play any dvd on my sony dvd portable(fx 850).
Sir try to check the video setting of your unit if PAL or NTSC. Good day and best regards.
tip
Playstation2 Region Free Fix
Sony Playstation 2 DVD Player Region Free Fix
Would you like to unlock your Sony Playstation 2 DVD Player to Region Free?
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free. However, many can be made region free, for free.
Follow these steps to unlock your Sony Playstation 2 DVD Player:
  1. Press and hold CIRCLE, RIGHT, L1
  2. Press and hold L3 and push the stick in hard
  3. Boot into the PS2 browser without a CD/DVD in the tray
  4. Press CIRCLE and R1 on the DVD
  5. Hold RIGHT until a menu appears
  6. Press CIRCLE and R1 again
OR
  1. Load the DVD into the PS2
  2. At the browser screen, select the CD icon the press and hold SQUARE then CIRCLE until the DVD menu appears, holding both buttons all of the time
  3. Either select the PLAY icon or the MOVIE START icon
Your Sony Playstation 2 DVD Player is now Region Free.
I hope that helps.
tip
PS2 DVD Region Free Fix
OR
I hope that helps.
on May 02, 2010 • Televison & Video
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
1helpful
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
1helpful
Black rectangle appears on screen while trying to watch movie
This happens all the time, on your remote, go into the Menu and disable Closed Captions. It will go away after that.
2helpful
Ws65909 Mitsubishi Tv and Dvd player
First forget the DVD.
  • Go into menu
  • and find close caption (TURN IT OFF)
  • If you find (TEXT) TURN IT OFF
those feature specially TEXT is who creates that square. was created for original programers to allow broadcasters send signals. Is not used for anyone. that squre is the empty space to write down a note. as i said not needed there TURN IT OFF. refer to your users manual to get easiest to this area. and read more about it.
2answers
Hitachi Ultrascan HD Black square question?
If that black box is generated by Tv, it should be there all the time, like on cable, av input etc.
as you said its not always, so cable top box is suspected which can generate such box as well.
I would suggest when you see that box in tv reception, simply play dvd player and check is that box still appears on dvd input? I hope black box wont appear in playback of dvd player.
Need further help, please let me know.
Black square on screen
Seems that you have to go into setup and look at the Closed Captioned screen set up.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
