Cell Phones Logo
p
poulami Posted on Nov 08, 2013
Not able to switch on Karbonn S5 Titanium
Using the charger the phone light is blinking, but not able to switch on
1 Related Answer
easybill99
Rani wadia
  • 996 Answers
  • Posted on Dec 25, 2014
SOURCE: My Karbonn titanium octane is always showing that
back up ur phone & hard reset
How to Add and Remove Numbers from Black List on karbon S5 Ultra mobile
To block a contact number: 1. Go to standby screen. 2. Go to viber application. 3. Go to its Menu. 4. Click on Settings. 5. Try to search the reject list. 6. Then add here the contact number you don`t want you to contact you. 7. Save. 8. End.
Read more: I want to block one contact from my phone its karbonn titanium S5 . Can you help me out how to block only one contact from my contact list? - Block one contact from karbonn titanium S5. I am unable to find it out. :: Ask Me Fast at
http://www.askmefast.com/I_want_to_block_one_contact_from_my_phone_its_karbonn_titanium_S5__Can_you_help_me_out_how_to_block_only_one_contact_from_my_contact_list-qna7934603.html#q6863630
https://www.google.com.bd/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwianJ35h_jKAhUEWx4KHfZQDtUQtwIIJjAC&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DTA8tYGEDFPI&usg=AFQjCNFO8Etj_8tweNJCCFz8brKIWU_y3g&sig2=ppdvtEAcUo0KEMYDXoGfsg&bvm=bv.114195076,d.dmo
1helpful
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 • Cell Phones
Karbonn k9 woning charging stoppd deu to hardware error problam
change the battery and use a original product charger
Jun 24, 2014 • Karbonn K9
I connect charger the message come charging stopped due hardware problem
That message appears for one of any number of reasons.
1) over-voltage (faulty charger)
2) under-voltage (faulty charger)
3) temperature (faulty phone / battery)
4) voltage regulation (faulty phone)
The best way to diagnose further is to try a different charger, and battery - I hope you have a friend who has the same phone as you!
Best of luck.
Oct 30, 2013 • Karbonn K9
10helpful
2answers
3helpful
2answers
I have Karbonn KC750 Dual GSM/CDMA phone. While charging get the messgae "bad contact of charger" and charging stops.
Use original charger.check and clean middle point of battery.Sometimes when the current comes abnormally this problem occur.
Aug 15, 2010 • Cell Phones
Top Karbonn Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
