Pride Motor Chair 2008 Vr2 Controller Speed adjustment lights go to fast setting but chair barely crawls along!
Great question! The slow flash is indicative of a speed reduced mode on models designed for a seat lift option. If the controller detects that the seat is elevated then the speed is reduced - regardless of what you try to do at the joystick.
First - try lowering the seat to its lowest position.
If this doesnt work then look for a bad or disconnected sensor switch on the seat post. There are two leads at a 2-pin plug that are not making a connection when the seat is lowered - causing the controller to sense the chair is not safe to drive fast.
SOURCE: I have a Pride 1143
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: Chair has new bateries but barely will crawl when
Contact your retailer and explain this to them. They are in the best position to help you with this matter.
SOURCE: My Pride Go Chair battery appears to discharge
Yes prob one of the batteries are bad, but you may want to replace both.
SOURCE: my pride go chair controller
How many yellow are flashing constantly? take a look at this link as well is this the type of controller you have and the type of display for the bars http://www.pgdt.com/scenter/diagnostics/diagvsi.html
if you have any further questions message me back and please remember when this chat is concluded to rank how this opinion has helped in your situation Thanks again
Rick
SOURCE: pride mobility Jet 3 Ultra
Hi, well as long as it's operating Ok, then we are all good,and perhaps it is something simple, such as there is NO profile, or a Profile hasn't been set, or chosen?
www.pridemobility.com/pdf/...Manuals/US.../US_Jet_3_ultra_om.pdf
above & below, are your manual so you can check settings etc.
www.pridemobility.com/...Manuals/product_owners_manuals.asp
Below is your troubleshooting website How To.
www.pridemobility.com/.../basic_troubleshooting_guides.asp
