If the loss of suction occurred during wet vac,the float has blocked the discharge vent , and this can be cleared by unplugging vac and emptying tank. if you tip the unit over while running it will close exhaust vent and can be cleared by turning unit off and wait 1 minute and restart unit.The most common causes of loss of suction are dirty filters or a clog in the hose. To troubleshoot, remove the hose from the vacuum, place your hand at the opening of the tank inlet and turn the vac on.
If you feel suction at the inlet, the issue is with your hose or accessories. Check your hose and accessories for a clog. If no clogs are found, check the hose for a hole or crack - even a small crack can cause a loss of suction. If a crack or hole is found, replace the hose.
If you do not feel suction at the inlet, turn the vacuum off and unplug from the outlet. Follow the steps in the user manual that came with the vac to clean the filter. Check the filter for rips or tears; replace with a new filter if any are found. Empty the tank or if you are using a collection bag replace it if it's full. Make sure the filters are properly installed then secure the housing to the tank. Plug the cord into the outlet, turn the unit on and place your hand at the tank inlet to check for suction. If you still do not feel suction at the inlet, turn the vacuum off and unplug from the outlet. Check the tank for any cracks and make sure the drain cap, if applicable, is secured to the tank.
If it is running and you have no suction, there has to be a clog in the dirt path. To clear it, start at the head of the vacuum (where the dirt goes in) take apart or disconnect everything you can along this path until you arrive at the bag or cannister. Take pics with your cell phone so you can reassemble it. Hoses: run a broom handle through all hoses to assure they are clear. If you have a shop vac or similar, try applying vacuum to all parts of your disabled vacuum in reverse. Are there filters on your machine? Make sure they are clean. You probably don't have hoses connected, but if you do, check them as I said.
I pick up vacuums along the road all the time. Very few are more than a few months old. All of then have a clog in the hose or elsewhere in the dirt path. I clean the path and sell the vacs for a slightly discounted price. VERY rarely is it a motor problem.
I hope you find this comment helpful. Here they are in under 5 minutes. Thanks for using FixYa.com
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656 Model 116 hose clog? Posted by rfrazelle on Jun 23, 2008 My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice? RJ Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared. http://www.sears.com/Customer Service1-800-4-MY-HOME1-800-469-4663 Thanks, Don the Vac Man Go Ahead. Use Us.
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
