Question about LG 37LG30 37 in. LCD HDTV
My LG flat screen says no signal or scrambled. What is the problem?
How do I fix a LG 55LH40 and it started showing 5 horizontal lines - now has multiple colors coming through everywhere and is unwatchable.
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. See and compare it to that of your TVs'.
Apr 28, 2014 | LG 55LH40 55 in. LCD HDTV
LG MODEL#RM-26LZ30 PICTURE seems scrambled and vertical lines trough the middle of screen
DEPENDS ON WHICH BOARD THAT NEEDS REPLACING. Look on Shopjimmy.com they list boards and parts. If you know how to solder I would first resolder boards and check for Bad Capaciotrs they will be puffed up on Top.
Oct 08, 2012 | LG Televison & Video
Lg-32LS3400 scrambled
re check the connection from the component input and tuner. then at the same time the system that you have using like NTSC or PAL, SECAM select the appropriate in your location.if still the same problem contact the supplier sine it was covered by warranty they checked the unit for free.
Sep 02, 2012 | LG 32LS3400 32" Class LED 720p HDTV
LG 8300 phone the display screen is distorted / scrambled
The problem with your phone is that the flex on your phone screen is malfunctioning, that is why the screen is distorted.
All you will need to do is to change the flex on your phone screen because it is now faulty.
Change the flex of your phone screen as advice and you will see that your phone screen will be back to normal.
Take care.
May 03, 2010 | LG VX8300 Cellular Phone
Intermittent pixel scrambling on screen (have AT&T u-verse/ Sanyo DS32920 Flat panel 32" TV)
Usually the result of a weak or interruption of the signal. If it occurs on all channels, look into getting an inline amplifier. If you have several splitters going to different tv's or a multiple splitter, the signal is degraded each time the signal is split. You can test this be temporarily making a direct link to the TV from the cable source. If it clears up, then you know you need to amplify the signal.
Feb 24, 2010 | Sanyo DS32920 32" TV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
LG 37LG30 37 in. LCD HDTV Logo
228 people viewed this question
Ekse
