I would like an external microphone for my canon fs200 camcorder but don't know if it should be mono or stereo.
SOURCE: Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
SOURCE: external stereo mic into camcorder not recording audio
You cannot simply attach a mike with a 3.5mm jackplug by using an XLR adaptor, the connections are all wrong. The only way to connect an XLR mike to the XM2 is by using an adaptor like the Beachtek XLR adaptor which is a superb bit of kit. I can't be certain of your problem but may I suggest possibilities? I wonder if the adaptor you bought was a stereo adaptor. If it looks like a larger version of the original plug then fine, if it has only the one long metal contact along the pin and then the tip separately, it is a mono adaptor. Using this on a stereo mike would work but it would be combining both channels into one which would degrade the sound and could give rise to your noise issues. If you have got an adaptor that is stereo, is it just the push in type? You can get adaptors that have a threaded barrel to screw the adaptor to the normal plug to lock them together tightly. If it hasn't got that, I would try putting the adaptor on the mike's 3.5mm plug and then taping it together to hold them very tightly together. This will stop minute movements between the two causing buzzing and other noises. I hope you find that of some help, my apologies if not. Rob
SOURCE: canon ZR65 camcorder issues
The CCD is not involved with playback, only the read heads. Your CCD could indeed be faulty. If the audio failed, it likely has circuit board issues which may affect the CCD even though it is working.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=227&modelid=8620
This page details FAQ's, and authorized service centers where you can get it repaired.
SOURCE: regarding the canon hv20 camcorder.
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
SOURCE: Canon FS200 camcorder: can I download to a mac? If not, what wou
yes, it does.
It only works with iLife 08 or 09, not older version.
It's easier to connect with a card reader to your Mac, Open iMovie to import. If via Camcorder, make sure Camcorder is set to display->Print/PC.
