If you are seeing an "E" bar on your computer screen and are unable to open it, it is possible that the "E" bar is a part of your operating system or a program that is running on your computer. The "E" bar, also known as the taskbar, is typically located at the bottom of the screen and contains icons for the programs and features that are currently open or available on your computer.
To open the "E" bar, you can try the following steps:
- Move your mouse cursor to the bottom of the screen, where the "E" bar is located.
- Click on the "E" bar to select it, and it should open and expand to show the icons for the programs and features that are currently open or available.
- You can then click on any of the icons to open the corresponding program or feature.
If you are still unable to open the "E" bar, it is possible that it is hidden or minimized. To unhide or unminimize the "E" bar, you can try the following steps:
- Press the "Windows" key on your keyboard to bring up the Start menu.
- Type "taskbar" in the search box, and then select "Taskbar settings" from the list of results.
- In the Taskbar settings window, you can adjust the settings for the "E" bar, such as its position on the screen, the size of the icons, and whether it is always visible or only appears when you hover your mouse over it.
- Make any necessary changes to the settings, and then click "Apply" to save your changes and make the "E" bar visible again.
If you are still unable to open the "E" bar after trying these steps, it is possible that there is a problem with your operating system or a program that is running on your computer. In this case, you may need to restart your computer or contact technical support for further assistance.
