Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
It did help to get the disc out, but I think the carousel is out of sync now. When a disc is inserted, and hit play it goes through all five discs then says no disc........is this the end of the unit, should I replace it? Your comments much appreciated.....thank you
