Memory fault?
LED meanings: http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c01726887-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&sp4ts.oid=3884098&ac.admitted=1383954759826.876444892.199480143
Server manual: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00700767/c00700767.pdf
Testimonial: "Thanks for you suggest, but can you give me the particular solutions ?"
SOURCE: the left led of is amber" is that fault exist on it?"
If you don't experience any network connectivity problems on that NIC, then you should not worry about this. This is a normal condition.
SOURCE: Second Led on HDD is flashing Red
you can run "chkdsk /r" coomand to recover your harddisk.
Also if you can delete partition and then create new partition thehn format it so all errors are fixed .
SOURCE: Why Internel Health LED Shown
the internal health simple tells that there is a degraded component
so in order to tell what is the component damaged you need to check the logs
or run a insight diagnostic report that is found at>
start/all programs/hp system tools/insight diagnostics
this report will tell you which is the components with problems
SOURCE: THE SYSTEM HEALTH LED BECOMES RED WHEN STARTS TH
The server may be overheating slightly. Check that it is dust free and has proper ventilation.
