Question about Philips CDR770 CD Recorder
Im trying to records mix cd but isnt changing
Im usin a phillips cdr 770 im a dj im trying to make mix cd but i cant change track manualy can some one help me
    Brigadier General:
  • 8,546 Answers
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
Posted on May 19, 2009
SOURCE:
Does anyone know if it is possible to record from a DJ mixer onto the Yamaha CDR-HD1300 CD Player / Hard-Disk Recorder? -- i.e Can I record a live DJ set straight onto CD? And/or can I record a live set...
The recorder could not care less what the upstream audio device IS or if it's live vs prerecorded as long as the connection works and there is a signal.
Jul 21, 2011 | Yamaha CDR-HD1300 CD Recorder
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
When I record a vinyl album on a CD it all winds up on one track.
Pause each song for every recording to separate the tracks.
Feb 23, 2009 | Denon CDR-W1500 2-Disc CD Recorder
How do get multiple tracks when djing
press the next botton on the recorder every time u switch songs djin".
Dec 28, 2008 | Philips CDR775 2-Disc CD Recorder
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Trying to find cd to record for a philips Cdr 770 cd problems
Open the unit (if you dare) and change the jumpers on the back of the playback unit. Now you can also use normal CDR's.
Dec 02, 2007 | Audio Players & Recorders
Philips CDR770 CD Recorder Logo
176 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
