There MUST be a generator attached to the engine of your genset to recharge the battery as starting current greatly reduces the charge of the battery. The solar panel was designed to "trickle" the battery to keep the battery "fresh".
My 11 month old Kohler 14RESL stopped working sometime this month. The GFI outlet to the trickle battery charger tripped and the battery charger went dead and so did the battery. When I realized the GFI had tripped, I reset it and the trickle battery charger started recharging the battery overnight. In the morning I tried to start the generator by pushing the run button - nothing happened except a message 'noEc' appeared on the status screen. I called Kohler and was referred to their local distributors.
After a whole day of phone calls to many distributors, I finally found one, Kraft Power, who would come out on an overtime basis and fix the problem. I chose Kraft Power because they were the only company who knew what 'noEc' meant. They told me that since the generator had lost all power (no trickle battery charger), the engine had lost it's configuration!
I have worked in the technical field for 25 years (computers, networks and remote diagnosis) so this answer was particularly troubling. THIS SHOULD NOT HAPPEN. The technician had to connect to the port on the controller, bring up Site Tech on his laptop, and enter two pieces of of information into the configuration. 1) 14RESL and 2) the engine type. We had to use a mirror to read the engine type as it was under the oil filter!
Hi
If the starter battery is not taking a charge, then it may have failed and require replacement. It is not uncommon for a battery that sits on standby for long periods of time to eventual fail. Best approach is to contact Kohler direct or one of their service agencies to get the correct replacement battery for the generator system.
You can contact them here
regards
robotek
Just check the Battery diagnostics if you have the software installed...If it is there then it will be in Start - Help & Support - Troubleshotting Tools - Battery Check.......If it shows the battery needs to be replaced contact Packard Bell...Since you told me that the A/C Adapter is not functioning and after you wiggled the lead it started functioning then if the battery test passes you will have to ask for a new A/C Adapter...
there is no alternator on small engines it is called a stater which is usually on the coil all one unit with coil but does the battery charge on a battery charger the battery might be bad & wont take a charge let me know if i can further help thanks wade
