Which operating system ?
Restoring your Windows 7 Gateway computer to its original
factory settings is a great way to get rid of pesky viruses you can't seem to
remove from your computer, or simply to remove old programs and files from your
computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a
result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway
computer to its original factory settings if you plan on selling it, or passing
it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of
your Windows 7 home screen.
Click "All Programs" in the Start menu, then click
"Gateway".
Click "Gateway Recovery Management" to open the
Gateway Recovery Management program.
Click the "Restore" header, then click
"Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration"
dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all
of the personal data on your computer will be deleted. Your computer will
automatically restart.
When your computer restarts the restoration process will
begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that
the computer has been restored to its original factory settings and that you
need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure
Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down
"Alt" while clicking "F10" during startup until you are
redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
90 minutes.
or if still no joy
http://www.almuseo.com/download-repair?Windows
7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are
almost always caused because of missing system files inside your Microsoft
Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we
suggest that you
perform an error scan.
This article provides related information that
explains the best way to repair your Windows Windows 7 0xc0000185 error codes
either by hand and automatically. Additionally, this guide can help you to fix
most regularly occurring error code messages connected with Windows 7
0xc0000185 error code which you might possibly get.
What ever I click the windows logo loads up like it should but then it stays loading and if i go to safe mode then its says things about replacing partations and I dont know that that means
