Dryer stopped working. When the start button is pushed, it hums, but does not work. When you let off start button, it stops. The drum does not turn. The belt is okay. It is only 15 months old. Warranty out in Febuary. Frigidaire Electrolux Model# Fer641FSO Serial# XD80102744
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
When you push the button, the dryer hums, but does not start. I turned the drum by hand, but still would not start. It is like a capacitor failure or something. After pushing it a few times, the start button quit humming. Now nothing happens. It still has electricity, in that, the light is on when you open the door.
Maytag. Does it have a capacitor?
How can the blower wheel be replaced?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Okay, I did what you instructed, and when I turned the drum by hand it did get it going. But it still doesn't work unless it is started by hand. Does this mean it is the motor?
