Check the speaker/s first. If found OK, check and replace damaged component/s at its audio out put section circuit. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/Timeslide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name / model
number / IC used, in the search box at the top right of the display window.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Note: The default audio setting for your notebook is Speakers / Headphones. You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
I don't know how you connect the unit to the tv. Let's just start on basic: composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV. If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable! Good luck!
HELLO . WELL THE DIFFRENCE BETWEEN THEM IS THAT THEY ARE TUNER'S AND THEY ARE SEPRATE FROM EACH OTHER.!!! JUST LIKE THE VHS TUNER'S YOU HAVE .!!! THERE IS THE PRIMARY WITCH .!!! WOULD BE (A) AND THEN THE SECONDARY WITCH WOULD BE (B) IT SOUND'S LIKE YOU NEED TO REPLACE THE AUDIO BOARD. OR THE (IC'S) ON THE BOARD. IT WOULD BE CHEPER TO DO. IF YOU KNOW HOW.? " WELL "GOOD LUCK"
