SOURCE: replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
SOURCE: replace hard drive on sony laptop vgn-sz330p
Most hard drives are easy to get at, not on this model tho. If you follow this link. At the top of the screen click on next for each of the stages or use the drop down menu. Site was a bit sluggish when I went on to check so be patient with it.
http://laptoplogic.com/resources/detail.php?id=43&part=resource&page=1
Good luck
I'd appreciate you rating me if you find this helpful
SOURCE: Where is HD on VGN-N250E
It's in the bottom left hand corner, as you view the laptop in it's normal position.
Sony Vaio's are not like other laptops in -> this respect.
With MOST other newer laptop's, you burn to disk your personal documents.
(Anything in your My Documents folder. My Pictures, My Music, My Videos, and personal documents you have created)
Then you buy an inexpensive external enclosure, (2.5" for laptops. And Sata for a laptop like yours), insert the new harddrive, and attach the external enclosure to your laptop, via a USB cable.
Then there is a certain key, or keys, you press on the keypad, and a menu comes up for transferring your Operating System, and programs you have installed, onto the new harddrive.
You remove the AC adapter, (Charger) and the battery.
The new harddrive is then inserted in place of the old one. Access to the harddrive, is usually removing a screw or two, then pulling the harddrive out, with part of the laptop body. Reinstall the battery, and plug the AC adapter back in. Away you go.
With the Sony Vaio series, this is not happening.
You have to use an external enclosure, and a 'mirror' imaging program, like Norton Ghost, Acronis True Image, or DriveImage XML, (Free), and mirror image the operating system, and programs to the new harddrive. (Via the external enclosure)
Then the fun(?) begins.
All electrical sources are removed. The laptop is turned over on it's top cover. Six screws are removed around the outside case edge.
One screw is removed towards the Front, and right next to the Memory Compartment Cover.
The laptop is turned back over, and a small flat tip screwdriver is inserted into slots, in front of the keypad. (Jewelers screwdriver)
The keypad is released and tilted back.
A flat ribbon cable is disconnected, from the motherboard that leads to the keypad. The keypad is removed.
Then, a small White flat ribbon cable is disconnected, in front of the keypad area. This ribbon cable connects the Front panel buttons, to the motherboard.
Now, the Top Cover is popped loose from the Bottom Cover. There is a thin parting line where the two halves meet, and a jewelers flat tip screwdriver, is inserted in this parting line towards the back. (Near the LCD screen) The Top Cover is eased up a bit, on one side, then the other side is eased up a bit. Work towards the front.
When getting to the end, (Front), the Top Cover comes off.
Now the harddrive can be seen. There are Two screws towards the Left side, in the corners. These are removed. There is One
screw towards the Right/Front corner. This is removed. The harddrive has a fabric pull 'tab' on the end of it. This is pulled on and the back end of the hardrive is gently lifted up, as it's pulled back. (Left side of harddrive is the back end)
-> Extreme caution is taken here, as there are tiny metal pins on the front off the harddrive, that can easily be bent!
There is a metal thin frame that goes around the harddrive. This is removed, by removing Two screws on each side. The metal frame goes on the new harddrive.
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
SOURCE: Laptop will not boot, Sony Vaio VGN CR220E, lights
I need you to try a few things.First remove the battery,memory no power whatsoever.Press and hold the power button for twenty seconds.Replace the memory then the ac cord and try again.Remove the power only this time and press and hold the power button again.Now replace the battery and the power adapter.Power up and you should work if not you will need to replace the motherboard.
Good Luck
