I belive the are around a 6 inch speaker tale out ur original speakers and measer across the speaker or if they are the crazy looking shape then i would take the original speaker down to the store u are going to and ask someone to help u find the shape and size
Go to the Crutchsfield catalog on-line and look up your car and it will show you and specify good replacements that fit. Their new interior door panel liners are also very good.
Bose Amps Are Very Propriatory ie: wire very Different, with special ends--They Can Be Replaced--However Will Cost More Than Worth--You Can Get OEM Amp From Salvage Yard--Which Is Much More Cost Effective. If Bose Speakers Are Present. Sound Quality Will Be Very Poor Or Nil If You Bypass Amp.
There is only one rule when you replace speakers - never buy a lesser powered speaker than the amplifier. Size is determined by the space that is available. The bigger the speaker the better it will perform and will be more efficient than a small on -- jut like a ceiling fan.
Left Front Speaker(+)
ORANGE/L GREEN
; Size:
Left Front Speaker(-)
L BLUE/WHITE
; Size:
Right Front Speaker(+)
WHITE/L GREEN
; Size:
Right Front Speaker(-)
D GREEN/ORANGE
; Size:
Left Rear Speaker(+)
PINK/L GREEN
; Size:
Left Rear Speaker(-)
TAN/YELLOW
; Size:
Right Rear Speaker(+)
PINK/L BLUE
; Size:
Right Rear Speaker(-)
BROWN/PINK
Yes , you can replace the 15 watt speaker with the 50 watt speaker. The impedance of both speakers (4ohms) is the same , so that's a match. Actually, the 50 watt speaker may sound a bit better at higher volume, because it will not distort as much as the 15 watt speaker. Hope this helps...
TAN
; Size:
GRAY
; Size:
L GREEN
; Size:
D GREEN
; Size:
BROWN
; Size:
YELLOW
; Size:
BLUE
; Size:
LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
sounds like the speaker needs to be replaced. I just replaced my speakers in my 01 silverado ext. cab with phoenix golg 6.5 inch subs and tweeters (a component set of speakers) and love the sound (RSD65CS is part number) www.dealercostcaraudio.com has them on sale for $59.00 I paid $75.00 www.woofersect.com has them on sale also for $59.99
