I am looking to buy replacement charging cords for a Vecor 141 power series spotlight. This is the big yellow light.
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
SOURCE: Need adapter for Vector 1 Million sport spotlight Model VEC156
if its the one im thinking of, i had the same problem.
if you look at the back and theres the male prongs to plug into the wall
well what i did was i took off the back
then i took off the cradle that held the battery in place, and stood it up on the lens and simply plugged it into the wall to charge it.
its kind of complicated but simple way to save some dough in todays market.
SOURCE: Vector power on board high intensity spotlight
Had the exact same problem. Checked the battery and discovered the red lead was off the battery. That's all it was. Works fine now.
SOURCE: Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Testimonial: "Thank you so much!! I do appreciate it!"
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
