Konica Minolta Bizhub C300 All-In-One Printer Logo
m
manish kumar Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C-dc30 how to reset code - Konica Minolta Bizhub C300 All-In-One Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 03, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913552
Points
11960
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
How to clear error code C-DC30 and C-DC10 on bizhub c452. Please assist. Thanks
CD030 and CD010 are both HDD (Hard disk errors) and cannot be reset by an end user (must use service mode for diagnostics). I am not finding C-DC codes you listed.
2answers
KM bizhub c 452 shows DC30 and DC10 when about to pick paper, how do I solve it?
CD 010 is unformatted hard drive
CD030 is admin data not on hDD
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Will a Canon Ax-dc30 fit the Powershot s120 ??
It does not appear to be compatible. See the list of supported cameras from the canon web site:
http://shop.usa.canon.com/shop/en/catalog/ac-adapter-kit-ack-dc30
How do I with error C-DC30
Well you hit the "Jack Pot" That code means some one attempted to COUNTERFIET UNITED STATES currency!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. Some one is in big trouble, There is not a thing you can do. You must get a KONICAMINOLTA Technician out to remove a special chip located inside the machine. It will be sent to KONICAMINOLTA then to the US SERECT SERVICE, since they protect US Money. Once a determination is made as to what happen. A new chip will be issued and new software will be up loaded. UNTIL THEN THERE IS NO RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1helpful
2answers
My Dyson DC30 keeps stopping and starting although the trigger is pressed
Look inside the recess that the battery pushes into...there are 2 prongs...gently twist these, so they are on a slight angle to each other (not parallel to each other)...this makes them 'contact' the battery better....especially if you have dropped your machine at some point. Fixed ours..dear wife was going to throw it out!
2answers
I have a Dyson model DC30 which runs for a few seconds and then shuts off, is there a solution out there
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC30 seems to be working intermittently. In order to confirm which part may be at fault we'd need to take you through some simple diagnostic checks.
When you have your DC30 fully charged and near to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Windows driver 7 or XP
Contact Pinnacle's web page. You can download the latest drivers they have.
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
