Washer makes a grinding noise whenever the drum is rotated. this happens whenever you rotate drum by hand or when it is in wash or spin cycle
May be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
grinding noise during wash cycle cabiro
possible foreign object entered drum
Wash drum noises
Machine drum not rotating
The new brushes may not be making good contact as spin is terminating early. Could a poor contact cause the operation of the valve when the drum is rotating fast?
while washing clothes the wash cycle makes a grinding sound,
Getting a squeezing noise when washer is the the spin cycle regardless of hen speed of the drum
