The amplifier works great at low to mid volumes, but when I turn up the stereo, the receiver powers down. Help!
If your head unit powers off at high output it could be several things.
1. check ALL your grounds (head unit, amp, etc..)
2. it could be a a short.
3. head unit could be defective
disconnect the amp power/signal and see what hapepens.
If it doesnt happen you probably have an open ground or short in your amp power or signal cables. Amp could be defective but that is unlikely
If it still dies when the amp is disconnected it is isolated to your head unit. Check your head unit's ground/power/fusing or swap in another head unit to eliminate wiring faults.
Good Luck!
