SOURCE: Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
SOURCE: My new treadmill belt is to tight, motor won't run
i discovered a bolt protruduing about one inch just behind the drive belt from the moto to the roller. The drive belt had gotten over the bolt and that was causing the interfearence.
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: The belt is tracking to the right side. I tried to
It sounds like you have a bad bearing. If you are not familiar with repairing/replacing bearings on a treadmill, I suggest you contact NordicTrak and have a tech come out and repair it.
