Question about Korg D888 8 Track Recorder
Driver korg d888 - Korg D888 8 Track Recorder
2 Suggested Answers
6ya staff
SOURCE:
techomecho
  • 430 Answers
SOURCE: Korg d888 power supply voltage
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Posted on Feb 12, 2012
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Hello! I got a hdd recorder and it's freezin' all the time. I think the hdd went wrong,but what if not.?
My experience with these is fairly limited. I find they have to be happy in all respects before they will work at all. When we had our digital switchover the signal strength quadrupled and many top boxes just stopped working while others kept freezing or pixelating. It wasn't until suitable attenuators had been fitted they settled down and began to work.
Lots of people who bought hdd recorders found them unsatisfactory and I know one guy who tried four before he found one that worked for him.
My first hdd recorder had a very short life so I upgraded and got an even worse one so I complained to the manufacturer. After several emails it seemed my new purchase had the oldest software version available. Since the software has been updated it has been quite acceptable.
You didn't say whether the trouble was with playback or tv viewing but I speculate there isn't much wrong if the device boots ok. The software will be stored behind a partition on the hdd. I suggest you check your signal strength and then try updating the software before resorting to sending the unit back for service.
Jun 16, 2016 | Korg D888 8 Track Recorder
Why cant i connect to my pc anymore
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
Sep 22, 2015 | Korg D888 8 Track Recorder
I plug the USB from the D888 to my laptop (Toshiba Satelitte with Windows Vista) and nothing happens. The USB button is turned on.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
Mar 23, 2013 | Korg D888 8 Track Recorder
When my Korg d8 power is on 'working' message is followed by Init>?, I cannot go beyond this. How to solve this problem? And can I change the internal Hard drive.
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Aug 15, 2011 | Korg D888 8 Track Recorder
D888 recorder/mixer wont boot up. Screen says "power on failure" initialize" appears that hard drive has failed. though I hear it running
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Aug 05, 2011 | Korg D888 8 Track Recorder
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
Korg D888 8 Track Recorder Logo
56 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
tmaree
tmaree
Are you a Korg Music Expert? Answer questions, earn points and help others
