Samsung Yepp YP-T9 Digital Media Player Logo
A
Anonymous Posted on Nov 06, 2013
YP-T9 V1.80.zip - Samsung Yepp YP-T9 Digital Media Player
5 Related Answers
A
Anonymous
  • Posted on Mar 23, 2008
SOURCE: help i have a Samsung YP-T9 and it froze
hold menu & a/b record at the same time ?
A
Anonymous
  • Posted on Apr 06, 2008
SOURCE: completely wipe a yp-t9 2gb
to get rid of songs you must go to mycomputer and look for
a mp3 icon click it.After that click on music and then right click and delete the songs you dont want
Anonymous
  • Posted on Oct 21, 2008
SOURCE: SAMSUNG YP T9
quiero bajarle musica
Anonymous
  • Posted on Nov 27, 2008
SOURCE: wont recognize my samsung yp t9 mp3
Go to device manager on your computer, go to USB(Universal Serial Bus), find your MP3 player, right-click, and click "update driver" At the new window, click "No not this time" at the next screen, click "Install from a list or specific location", then at the next one choose "Don't search", then click your MP3 and click "next" it will then update to recognize your mp3.
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Samsung YP-T9 Driver
Problem video
1helpful
I reset my samsung yp-t9 to get all my songs off and all it has is a black screen that says usb mode... and wont do anything els how do i lis to music
you need your firmware be upgraded
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=YP-T9JQB/XAA#
download zip version and put the rom file into yp
3helpful
How do you put videos into the YP-T9 mp3 using windows media player??? Would I have to convert the videos somehow? I've been having trouble with this, please help!
Look sir.The yp-t9 can only play svi files.In order to put the videos into your yp-t9 you must hav samsung media studio and also the videos must be in either mp4,avi or wmv format.And then use Samsung media studio to put the videos into your yp-t9,samsung medai studio will convert the videos into svi format which your yp-t9 can read.
19helpful
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
2answers
YP-T9 update
i lost library update samsung yp t9. ihope all of you can help me to find my solution.thank's
please help me
1helpful
Videos
Yp-t9 only plays svi files.First make sure the videos you have are mp4 or avi or wmv.Then open samsung media studio.If u dont have it then download it.After that put the videos in your yp-t9 using the samsung media studio.The samsung media studio should convert those files into svi format which can be read by your yp-t9
1helpful
1helpful
Problem of frezzing and non asistance for my samsung tp-t9
Look sir.The yp-t9 has a minor problem of freezing.When it freezes just press the rec button and menu button together this would reset your yp-t9.This will help.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
