The motion lever is floppy loose and a spring on it seems disconnected or broken. mower won't move forward or backwards. when transmission is disengaged can't push as it is still in gear
• Move motion control lever to neutral (N) position.
• With engine running, turn ignition key counterclockwise
to ROS "ON" position.
• Look down and behind before and while backing.
• Slowly move motion control lever to reverse (R) po si tion
to start movement.
• When use of the ROS is no longer needed, turn the
ignition key clockwise to engine "ON" position
Manual is available at: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007-PB175H42LT-405327-96017000401.pdf
Mower won't move forward or backwards
Mower starts; throttle adjusts rpms; hydrostatic gear shift doesn't seem to engage (move from Neutral to forward and Reverse and go nowhere)
Husqvarna zero turn mower hydro pump makes noise I move forward. I want to rebuild pump but I don't know which internal parts would fix the problem. I found seal kits online but I can't find a general kit that would replace all the internal parts. Pump# bdp-10a-404
