SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
SOURCE: BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
