I have an Onkyo TXSR503 receiver. I have sent it in for repair three times, for basically the same issue. It has failed again in the same way. The protection circuit turns the receiver off after a few seconds. I have no doubt that if I send it in again for repair, it will fail once more.
Not only did the repair not hold, they didn't even fix all of the problems. The last time it was returned , two of the channels, the surround back, left and right did not work. No doubt they will try and blame this on me, a little hard to accept as these channels had not been connected before they failed.
I don't think Onkyo will do anything about this other than having it "serviced" again. Then when it fails this time, the warranty will be expired and I'll end up buying a new receiver, not an Onkyo by any means.
Other than letting as many people as possible know what a POS Onkyo sold me, and how bad their service centers are, I don't know what to do.
I've tried all that stuff. At this point I'm convinced that if I send it in for repair, it won't do any good. They sold me an expensive paperweight.I've tried all that stuff. At this point I'm convinced that if I send it in for repair, it won't do any good. They sold me an expensive paperweight.
Same problem. Maybe after turning the receiver on more than 20 times and moving volume up or down, the unnit will stay on. I've tried to fix the problem myself following the instructions in the manual. (As if ONKYO already knew about the problem.) Brought it to authorized service center in Providence, RI. Had to wait a few weeks and was treated as if I was dumb. Checked all wires and speakers for shorts with multimeter. All were fine. The thing even turns off when nothing is connected. Called NJ main service number. Got a somewhat condescending answer. I can ship my unit (!). I expect less of a hassle when there seems to be a serious system fault. The unit was fine for a few months. Once it stays on, the sound is good though.Same problem. Maybe after turning the receiver on more than 20 times and moving volume up or down, the unnit will stay on. I've tried to fix the problem myself following the instructions in the manual. (As if ONKYO already knew about the problem.) Brought it to authorized service center in Providence, RI. Had to wait a few weeks and was treated as if I was dumb. Checked all wires and speakers for shorts with multimeter. All were fine. The thing even turns off when nothing is connected. Called NJ main service number. Got a somewhat condescending answer. I can ship my unit (!). I expect less of a hassle when there seems to be a serious system fault. The unit was fine for a few months. Once it stays on, the sound is good though.
AnonymousNov 18, 2007
Same problem. I get about 20 seconds before it shuts down.Same problem. I get about 20 seconds before it shuts down.
AnonymousNov 21, 2007
Same problem. Mine has been "repaired" four times under warranty. Had my speakers checked, thought it was the center channel, unit shut off with no center channel hooked up. Advice I got was to get a different receiver.Same problem. Mine has been "repaired" four times under warranty. Had my speakers checked, thought it was the center channel, unit shut off with no center channel hooked up. Advice I got was to get a different receiver.
rearanging speakers and speakers wires touched and then the protect came on.
Same bull Sh-t with mine. No help from Onkyo either. I hope Onkyo goes **** up and they all loss their jobs rearanging speakers and speakers wires touched and then the protect came on.
You can't post conmments that contain an email address.
All speakers and lines OK? Sorry for basic approach!! Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters. Also, re the "last return" ... Maybe the back surround speakers were turned off in settings? Again, apologies if you've tried all this basic stuff. I've just bought one of these amps and have probs with the FM tuner not tuning anything. Mmmm. Back to the shop?? Cheers, Chris
I bought my 503 in 2005 and after two years it started doing the same thing. the amp protection relay kicks on, if I hit hte power button about 10 to 15 times it will stay on and work fine untill the next time I turn the system on. I did all the steps that Onkyo shows. un plug everything and turn it on. it didnt make a difference. there are 4 relays on the PCB board, one is enicial power on, one of them is the amp protection relay, not sure which one tho. Onkyo doesnt seem to know anything either.
If your unit qualifies, a box and prepaid shipping label will be sent out. Please note that as part of the repair process, the firmware will be upgraded and all user settings will be reset to factory defaults. The average time for repair is 7-10 business days after the unit arrives at the service center.
PLEASE NOTE THAT IF ANY UNRELATED ISSUES ARE FOUND, YOU WILL BE CONTACTED WITH AN ESTIMATE TO HAVE THOSE ISSUES REPAIRED AT YOUR OWN EXPENSE, OR AS PROVIDED BY OUR STANDARD WARRANTY POLICY. PLEASE REVIEW THE LINK PROVIDED ABOVE FOR FURTHER DETAILS
If your unit qualifies, a box and prepaid shipping label will be sent out. Please note that as part of the repair process, the firmware will be upgraded and all user settings will be reset to factory defaults. The average time for repair is 7-10 business days after the unit arrives at the service center, Thanks, JT
Overview:
I’m writing this report to provide insight into a common Okyo issue.When my Onkyo receiver began to malfunction my first response was to search the web for answers.What I fond was conflicting information. While all system issue may be unique, I hope this report shed some light on the subject.
System Breakdown: Receiver: Onkyo TX-SR606 7.1 Channel Home Theater Receiver (Black)
TV: Samsung - LN52A750 - 52" LCD TV - 1080p
Broadcast: Comcast
Component 1: XBOX 360 Elite
Component 2: PS3 120GB
Cables:Mediabridge Ultra Series - 10ft High Speed HDMI Cable - Version 1.3 Category 2 - 1080p - Blu-Ray - PS3 - W/ Nylon Sleeve Issue: When I first setup my Onkyo receiver it worked perfectly.Over time, my TV would display “Searching for Signal”.After about a few minutes the receiver would detect the XBOX 360 and work fine.At first it was no big deal until the problem progressed. The receiver began to take longer and longer to detect the signal from the XBOX 360.Finally it would take up to 30 minutes or would not detect a signal at all. Finally I went through the process of changing out the HDMI cables and switching ports.This did not work, so I call Onkyo.They walked me through a reset process that did not work.Finally they recommended that I take it to an approved Onkyo repair shop. Lucky for me there is a repair shop in the suburbs of Chicago about an hours drive from my location.There are not many approved Onkyo repair shops. Most people would have to ship their receiver to another state. I took the receiver to the repair shop.They seem to have a nice little scam going on… Here is the scam.. They tell you there is a 3 to 4 week wait time (or longer) until they can even look at your receiver! BUT, if you want to put it on the “Priority List” you can pay a $30 non refundable fee not covered by your warranty.Then you would only have to wait about a week.Tell me, who would not op for the priority list when your entire entertainment system is managed by the receiver?!?!?So I payed the $30.About 4 days later I get a call from the repairman.He says, all the HDMI ports work but they don’t have an XBOX 360 to hook it up to.So he can’t validate the problem.After arguing with him for an hour and listening to him cry about how crapy Onkyo receivers are and how hard the company is to work with, he agreed to do some research into the problem.I told him many times, simply look on the internet many people are having the same problem.Onkyo has to know something about this. Finally about a week later I get a call from the repair guy.He says he thinks he knows what the problem is.He has to order some capacitors and I could pay $45 for priority shipping.Umm wait one minute, I already paid $30 for priority service now you want me to pay more for shipping?No thank you!Over time I simply rewired my system to work without the receiver and to tell you the truth I almost forgot about the receiver.Finally I got a call from the repair shop about 2 months later saying I could come pick up my receiver.I talked to the repairman. He said the following… Solution: There are 4 capacitors that malfunction over time.It’s a common problem with Onkyo receivers. When the capacitors begin to malfunction you get intermittent signal response until it does not work. He could not explain why the cable still worked (everything was hooked up with HDMI cables). If you are experiencing this problem. I hope this helps save some time switching out cables and guessing why your system is not working. - Antious
Again, onkyo has downloadable cd software (its free) that you run threw cd player via fiber optics that will fix the issue. onkyo.com,choose region,click support at the bottom of page find Download Center or Software Downloads/Updates: for info. With onkyo its usually a simple chip issue. If that fails , find contact support , e-mail them your issue and simply ask for a downloadable repair disc- I did.
HDMI must be hooked directly to the TV and optical or digital coaxial to the receiver. Your receiver has 1.1, 1.2 or 1.2a HDMI firmware and hardware. There is no fix for this issue w/out a new receiver that has 1.3b firmware. All receivers on the market have this issue, not just Onkyo. HDMI comes directly from HDMI. And there customer support !@#$%^&*()!!! Sorry for the bad news! but that's the fix. Hope this helps.
HI, this is a reset procedure that this unit is trying to initiate. there has been a surge of some sort that the system has survived but, there is some lasting damage as well that has resulted in a slight programming error within the mother board.
This unit has a program that was installed at the manufacture. it runs the basic operations. there has been some major damage that is causing the internal program to stall and reset itself. the only way to reprogram is to send it back to the manufacture or, you can locate a local repair depot through Onkyo. the Onkyotechs are the only option when re programing is needed.
This sounds like it has a microprocessor problem. Try unplugging it from the wall and leave it overnight. That will give the microprocessor a chance to reset and then try it again. If it continues to do the same thing, you need it serviced by a professional technician. I am sad to say, there are no easy fixes for a microprocessor problem.
Onkyo receivers are very good quality and are normally worth getting repaired. If it were junk I would tell you to just buy a new one. But even the very best equipment can fail. I have been repairing audio equipment for nearly 18 years and have never seen any brand that did not have some type of failures at some time or another. Onkyo's may not be the most expensive receivers, but they are some of the best engineered receivers I have worked on.
I hope this helps you decide what you are going to do, and hopefully after the micro is reset, it will work good again.
