I recently downloaded a video for coby and changed them into MTV format in order to get them on my coby. I sychronized the video I wanted to the coby with no problem or error. When I unplugged the Coby (I used the eject button and waited untill it said I could unplug) and went on to the MP3 player it did not show the video. I double checked and sure enough, my video was in the MOVIE.DIR file.
I don't know why it is not showing up on my Coby and help would be appreciated.
Hi princessb515...
You are trying to play a video with the wrong video format...you have to change the video format for it to work on your MP3 player...
Check your manual to see what video format it needs...
It will probably be MP4.
Go to this webpage and download your FREE media format converter...
Please take time to rate me thumbs up
Check the specification of your MP3 player to determine thetype of video file format it uses.
Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.
If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses.
Click on this link for instructions on converting videofiles for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Video Format Support MTV You need a mtv converter ...after you convert your video files from .avi ,mpeg,or any other format...transfer the converted files to your coby player MTV converter free download .
Support for Coby media players is on cobyusa.com .
For the mtv converter, Coby Media Manager must be installed .
Enter cobyusa.com as the address in Internet Explorer
Next select the Support link
Choose the fix for MP822 and follow the steps for the download of your operating system.
After the download, install the file for Coby Media Manager
Run Coby Media Manager: on page top in Tools > Device manager... select the MP610 in this converter.
Add the MP610 and click OK to setup this device
For the setup of the audio format added to the mtv video format, select DEVICE on the left side and next on the right side under MP610 select Device Configuration
For the MP610, under the tab [Output file format] the audio bitrate can be changed, the audio format is fixed MP3; the video format is fixed MTV; the image format is fixed JPG .
On page top under Help find more information about using the software.
I'd appreciate your vote when this information was helpful. When needing more help, just post a comment.
Your Coby MP-610 Player is capable of viewing MTV file formats with maximum video resolution of 160 x 128.
There are many MTV video converters available on the net but i strongly recommend the E.M. Video Converter by eTinySoft to convert your movies into MTV format and play it on your Coby MP-610.
well when i used coby media manager it had a video converter in the video option on the side.i had to register my coby before the software use with its serial # on a sticker located on the back of the device! then i simply used the sycronize feature in the video option on the coby with a video preferbly avi files or others and right click syncronize and it should convert it and then transfer!
You can go to the coby website they have a zip file download with converter....Just download it and install.I find however that you may have some issues converting .avi files.I think its because avi is a container not really a formatt of such...so not all .avi files are the same.Try converting from .mov format ..That is Quicktimes format.
I had to recode or reconvert my downloaded youtube .flv video from .avi to .mov before the MTV Video converter would work right.The output file will be a .mtv file.So try using .mov files instead of .avi.
