I have auniden bearcat 10 channel scanner and need to put codes into it how do i go about it
dont know how to program my uniden bearcat bc350a scanner.....
If your scanner is the BC350C (the section you posted in), here's a link to the owner's manual which will give you detailed programming information:
http://www.uniden.com/pdf/BC350Com.pdf
If you have a different model Bearcat scanner, try:
1. Push MANUAL to stop scanning and advance to the channel that you want to program.
2. Enter the desired frequency, including the decimal point (e.g., 156.015).
3. Press E or ENTER to set the frequency.
4. Repeat the process, starting with 1 above to select the channel.
NOTE: With some Bearcat scanners you may need to press the E or ENTER key before entering your frequency.
These are general steps that work on most recent Bearcat models. If they don't work on yours, try different variations. You can also check Uniden.com -- they may have an online manual that you can download and print.
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
