TV won't turn on. When plugged in, the red standby light next to the power button blinks twice 5 times in a row and then starts over doing the same thing. When power button is pushed nothing happens. The light just continues blinking in the same pattern.
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
there is an IC need to be replaced it will cost you 1 dollar
CAN YOU TELL US WHAT IS THE IC ?
yes please what is the IC
SOURCE: Samsung remote control problem
Same issue as lisawrob
Check to see if there is another remote with something sitting on top of it. I had the same problem and found another remote transmitting (continously).
SOURCE: samsung 50in tv trouble getting it started
the color wheel is bad. this whirring noise is caused from bad bearings in the 12v motor and possibly broken plastic panes from the wheel. DO NOT KEEP TURNING ON AS THIS CAN THROW PLASTIC PIECES INTO THE LIGHT ENGINE TUNNEL. very hard to retrieve debris from light engine. even small fragments can show up as large blemishes on the screen once the pix is magnified. needs professional service as light engine must be removed and realigned after replacement. mch
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
SOURCE: Samsung remote won't turn 630 LCD off. Only volume works.
yo moel
the way i did it was take the batteries out and hold powere button for 5 seconds put batteries back in and should be fine mate!
ahmed
SOURCE: The TV button at the top keeps blinking and the
This light is caused when there is a fault with the circut board. If you are able to get the remote apart you might fid some liquid lik substance on the board. take a cotton bud and clean it dry put the batteries in it and it should work like new
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
