pressure method. 1. Start by turning off your monitor. 2. Find a pen that has a rounded, dull end and get a slightly damp cloth to protect your screen. 3. Fold your cloth in two so that you do not puncture it accidentally. You don???t want to scratch your precious screen, do you? 4. Put the cloth in front of the stuck pixel and start applying slight pressure on it with your pen. Do not put pressure anywhere else than on the defective pixel, or you may break additional ones. 5. Continue applying pressure, and turn your monitor on. 6. Remove the pen from the screen, and voil? ! The stuck pixel should be gone.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Did you white balance both cameras in the same setting? Sounds like one was balanced in different lighting than the other; i.e., if you white balance a camera outside and then bring it inside, the colors will be "off" as you describe.
Hi! Do you mean that these pixels go to pictures too? Then they are dead pixels on the imager (CCD) not the display. The CCD has to be changed - you have to contact Panasonic service center to find out the price (could get expensive).
Things to try. I don't promise solutions. Check your Monitor. Reading the description lead me to think of a tube display rather than a chip. Otherwise order a head cleaning tape and give it a rotation.
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels.
Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue.
Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes.
If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair.
Notice the green defect pixel near the center of this image.
