"DEMO MODE" is a tool intended for in-store demonstration of the microwave oven to the consumer.
While in Demo Mode, if you push "START", the microwave will not fully operate as designed.
To Exit Demo Mode, press the "Timer/Clock" button four times. If it does not work, see to your operating manual.
I went to purchase a new remote on line and they had a tip that work! Don't ask me how. Take the batteries out. push all the buttons one at a time at least once, replace the batteries CORRECTLY and try the remote Mine worked!
The four wheel drive systems in these vehicles are simple. The push button controls the four wheel drive computer. The computer tells the encoder motor (on transfer case) to shift. When the transfer case shifts there is a vaccum switch on the transfer that is activated which sends vaccum to the accuator under the battery. The accuator pulls a cable to lock the front axle in. This covers all s series trucks and suv's with push button four wheel drive but not with auto or all wheel. Now to answer some questions. If your push button is lit up but will not go in to four high you should try to reset the four wheel drive computer. To reset pull the courtesy light and atc fuses for sixty seconds install fuses then cycle key on and off 5 times. If your transfer case shifts but your front end does not lock in check for vaccum at the switch on the transfer case in and out. If no vaccum out replace switch motormite number 49315 at parts store. If you have vaccum out check accuator.
