It could be the Wig-Wag needs replacing. But are there any fault bleeps or flashing lights. If so count how many and check in the trouble shooting guide of your user manual to tell you what the fault is.
This sounds like an Ancient model......LoL ! The Wig-wag shifts between agitate and spin. They went bad often ! Is this a pre 1985 Model ? If so, the wig -wag is a possibility. If it agitates, the belt is still good.Hope this helps.
not that unique, whats happening is the transmission has a wig wag and
shift cam bars that are not moving at the right time. you probably
have an open coil on the wig wag and its normal for them to do this
when a coil fails. just take the 5/16 screw out of the wig wag and
lift it off the plungers, then replace it with a new one. all should
work correctly after that.
ok so now i have seen your ? 4 times and you dont need a basket drive either. you might want to make sure you didnt unhook a wire from the wig wag when you changed the motor and it could also be the cam bars are just stuck, which ever, just look at the wig wag and bars. that will be your area to repair.
