Question about GE JVM1650 1000 Watts Microwave Oven
The microwave starts, then stops 2 seconds later
When i set the timer to cook food, the microwave will start for a couple of seconds (two at the most) then will stop. the display will then say, "set clock".
  • 16 more comments
  • Anonymous Nov 25, 2007
    I have the same problem w/ the GE JVM1653 Microwave. I found in another forum that if you remove the top vent from the microwave and hang the control panel down at a 45 degree angle it will work..but only for so long. Plus it is dangerous having the wires exposed and running the microwave. Anyway, it is back to the same problem. After starting the microwave, it counts down 2-3 seconds and then freezes up requesting the date and time be entered again. It is a $300 clock. The most annoying part is it also states: GE we bring good things to life ...NOT
    I called GE and there is no service technician in our area. I am fighting w/ their consumer relations department. They keep telling me I am out of luck b/c the warranty just expired. I am very disappointed in GE customer service, this product and this experience. I created a yahoo email account to try to gather consumers together that are having this problem b/c GE customer relations says no one else has reported this issue (which I find hard to believe). The email is gejvm1653dispute@yahoo.com. Please email me w/ your microwave # and I would be happy to put a complaint in to GE w/ all of our names. Maybe we can all be reimbursed. If not I will go to the Better Business Bureau.
    Thanks!
  • ranboz Dec 03, 2007
    Same problem. Model from February 2005. It stopped working about November 2007 - after the warranty expired.
  • mitaylors Dec 21, 2007
    Same problem. I don't know where to start. I don't think I trust having exposed wires since I have young boys who use the microwave. Sounds like I'll end up buying a new microwave--but not GE.
  • Frank2 Dec 23, 2007
    Same problem. Microwave shurs down within two seconds then displays "set clock". It works without sutting down if the control panel is tilted outward. There are no loose connetions behind the control panel. I am still working on a solution.
    Frank
  • VenusV Dec 27, 2007
    Same problem...Also a GE JVM1650 manufactured in Feb 2005. Called GE and the service call alone will be $75. They can not give me an idea of what the problem might be. They can not give me a menu of what certain parts and the labor for them would cost. They can not even give me a local number so that I can ask these questions of the "GE Certified Repair Professional" who will be coming to my home. I feel like I'm about to spin a roulette wheel! Maybe it'll only cost $150, maybe $450...Who knows?
    It is too much of a coincidence that we are all experiencing the same problem from models produced around the same time. I cannot understand VEKAT's solution and do not know what to do next.
  • RogerGA Dec 31, 2007
    I also have a February 2005 JVM1650 that is doing the same thing. Could this be a bad run at the manufacturing plant?
  • ish61 Jan 03, 2008
    Same problem GE JVM1650 spacesaver manufactured April 2005. Initially I would reset time / day and it would work periodically. Now it turns off after 2 secs all the time. In mid December I called and received the same answer about a $75 service call. That's before parts, etc.
    This is pitiful after only 2 years a light to moderate usage.
  • Kerwin Jan 05, 2008
    We have the same problem with our JVM1650. Some times it works fine and the next it will shut down repeatedly. This is very anoying and even though it's good to know we are not alone that does not fix the problem.
  • Anonymous Jan 05, 2008
    I had the same problem with my GE JVM1650 today. Model from Jan 2005. Looks like a trend that requires a recall.
  • dadurling Jan 07, 2008
    JVM 1653 with same problem. Believe it was mf'd in early 2005 because we bought in in April 2005. At first, I could reset the GFCI outlet and it would work again. But now I can't get it to work. Same issue with GE service: they don't have a local repair guy, although I have left messages with GE-authorized repair centers and am waiting for a call-back.
  • Anonymous Jan 09, 2008
    I also have a GE JVM 1650 I bought it 4/13/05 and in Nov 2007 I started to have the same problem I set the time to cook and sit runs for a few seconds and turns off and I have to set the clock again. I called GE and she could say to me is that it sounds like the control panel and you will need service. then she give me 2 phone numbers to call and tells me a service charge is between $70.00 & $100.00. I don't feel I should have to pay the microwave isn't even 3 years old. I had a free standing no name that I bought from walmart for $70.00 6 yrs ago and my sister still uses it. GE needs to stand by there product and either fix or replace these there is obviously a problem
    Microwave is just over two years old and doing same thing. Had repair man out twice due to extended warranty. First he thought it was board, was replaced and same thing happened still. Second time came out an he contacted ge, was told that there were complaints about same problem and nothing could be done unless he could find problem and trace the problem back to what was causing it. I don't understand how ge can treat customers like this. How about standing behind your products.
  • irelandsown Jan 13, 2008
    omg.... i have the same problem with the two second deal and its off.... the microwave is only two years old..... im glad im not alone. guess im going full steam ahead at ge.... they will replace it or go to attorney general
  • Anonymous Feb 08, 2008
    I have the same problem. The microwave stops after 2 seconds. I purchased it in the summer of 2005. This problem started in January of 2007. GE is no help to me. This is just not right as hundreds of people are having the same problem. Now I have a $350 clock.
  • Anonymous Feb 21, 2008
    It stops after a few seconds and wants needs the clock and date re-installed, then when started again, it stops.
  • Anonymous Mar 12, 2014
    Microwave will start for couple seconds then stops?
  • Anonymous Mar 28, 2014
    problem with halftime cooking or microwave cooking
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
I'm having the same problem with my JVM1650. I paid over $300 for it about 2 years ago. It was manufactured in the summer of 2005. It goes on for 2 seconds then shut down and I need to reset the time and date. Why is there no recall? Has any gone to the BBB?
Posted on Feb 07, 2008
    Champion:
  • 225 Answers
First set clock, after you set programme.after that also same problem study instruction manual before operation of microwave oven. after that also same problem check control unit circuit and related..
Posted on Oct 05, 2007
SOURCE:
It not cooling
If you're talking about a microwave oven:
[1] plug the mains cord in to the wall socket
[2] switch the socket on
[3] put food to cook on glass turntable, never use empty oven.
[4] close oven door fully until it clicks
[5] set the power
[6] press 'start' or turn the timer-dial,depending on your model.
It will start to cook immediately.
The humming sound is the energy heating the food in timed bursts of power.
If nothing happens or it won't cook, post clear description of fault with problem, make, model.
Hope this helps,
Clive.
Oct 19, 2017 | Microwave Ovens
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
MICROWAVE RHM1709B-G keeps cutting out when cooking
You're going to need to replace the oven
Jan 05, 2018 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Have a Proctor Silex small crock pot, no manual. Setting are Off, 1, 2 and "AutoShift". There is no timer. How can it be set to (1) be sure to cook the food long enough and (2) stay on / keep...
You can find a Use and Care Guide for your product at the following website. You will need to locate the model number of your crock point. Select Slow_Cookers in the product field; Select your model number and click on Submit.
A pdf file of your Use and care Guide will be provided; note they are scanned files and some are of poor quality.
Model 36400 has a similar control to your model. The Guide provides a table of the time to cook at settings 1 (low), 2 (high) and Auto Shift. Auto Shift starts at the high setting and then decreases to the low setting. The time to cook at Auto shift is in between the time taken at the low and high settings. The low and Auto Shift settings are designed for long cook times at a simmer. On the high setting some foods like soups will come to a boil and may need stirring during cooking.
The crock point has no auto turn off and will keep foods at a simmer when on the low or Auto Shift settings. With some practice you will learn how much time this will take for various foods.
The sure way is to use a tip sensitive digital instant-read thermometer to check the final temperature of the food. Check according the guidance provided by the Partnerships Food Safety Education:
http://fightbac.org/safe-food-handling/cook/127-cook-heat-it-up-chart?format=pdf
Feb 06, 2011 | Microwave Ovens
When you start the microwave it starts normally with a low hum, then a couple of seconds into it the hum gets louder. After the cook time has expired the food is still frozen. Is there something I can do...
Replace the magnetron by the sounds of it. The hum gets louder a second or so into "Cooking", that would comply with the magnetron heaters coming on and working into a dead magnetron. It could be capacitor or diode of course.
Dec 27, 2010 | GE JVM1540SMSS Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
2,633 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
