A
Anonymous Posted on Nov 06, 2013
Bizhub error EA222a - bizhub Konica Minolta Office Equipment & Supplies
Ubaid abid
Level 2:
Guru:
  • Expert 164 Answers
  • Posted on Apr 17, 2019
Ubaid abid
Expert
Level 2:
Guru:
Answers
164
Questions
0
Helped
122966
Points
609
  • Fusing Warm-Up Failure (Main) - The Fusing Roller Thermistor does not detect the required temperature within 30 sec.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
2answers
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
