Question about Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
NO POWER IC 801 BLOWN UP ON BN44-00482A
NO POWER
I need the value of ic 801 in tcl model 21k77
Description ic801. Is a bias controlled monolithic IC VHF/UHF RF AMPLIFIER CMOS SINGLE CHIP 8- BIT MICROCONTROLLER hope this helps
Jan 29, 2016 | Televison & Video
My acer aspire one netbook will not power on, all i get is a steady orange klight when a/c adapterr is plugged in. any help?
The problem must be with either power adapter or BGA-IC
Check whether caps lock light works if so power ic is gone else BGA-IC must have blown off.
take it o authorized centre and check the laptop
Jan 30, 2013 | Acer Aspire One Netbook
THERE IS NO audio frm my fisher tad-9925.....the ic has just been replaced but still no audio.....cd is playing but cant hear anything
Its a little hard to diagnose over the computer.
I assume there is no sound from the amp EVER.
I assume you have tried other sources.
I assume the unit worked OK until the IC blew.
I assume you replaced the IC yourself?
Often, parts with the IC also fail. There maybe fuses that look just like little resistors along with the IC. They might be blown.
There are parts in the circuit to test if there are speaker problems called power resistors. These will frequently open circuit when the IC Blows - you won't be able to see anything visually.
If your stereo normally makes a 'Click' sound just before the sound comes on, and now there is no click, this indicates the repair of the IC is not complete yet - find the blown part.
Mar 22, 2010 | Fisher 9925 Shelf System
Sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Jan 21, 2009 | Sony Televison & Video
TV will not turn on
does the standby led goes on, or non at all? if not, check power supply section, look for blown fuse or open resistor in the power supply section. check also the power regulator IC...
Sep 28, 2008 | Olevia Televison & Video
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
173 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
